Web Service Tier and NAS fail, but RTC Service Tier OK
Hi everyone,
We’re on NAV2009SP2. I was adding a second service tier connected to the same database for use with “Easy Security”. Our current service tier is set for port sharing. I used the tegos Service Tier Administration tool to create the new tier.
I could not connect to the new service tier using RTC. I received the same application log errors as mentioned below. However, my real problem is now the ORIGINAL web service tier and NAS will not connect. There are several application log entries. Some of them are long - I apologize for the length - but here they are. In addition, I also did see a log entry that said “The call to member Open failed. Microsoft OLE DB Provider for SQL Server returned the following message: Invalid connection string attribute”.
The services run under a domain user which did not change. I DID create a new domain user for the second service tier, but it is not used in the connection settings for the existing service tiers.
Anyone have any ideas?
Warning: schemas.microsoft.com/.../TraceRecord"](http://schemas.microsoft.com/2004/10/E2ETraceEvent/TraceRecord) Severity=“Warning”>msdn.microsoft.com/…/TraceIdentifier>Faulted System.ServiceModel.Channels.ServerReliableDuplexSessionChannelMicrosoft.Dynamics.Nav.Server.exeSystem.ServiceModel.Channels.ServerReliableDuplexSessionChannel/30142872
Warning: schemas.microsoft.com/.../TraceRecord"](http://schemas.microsoft.com/2004/10/E2ETraceEvent/TraceRecord) Severity=“Warning”>msdn.microsoft.com/…/TraceIdentifier>SocketConnection abortedMicrosoft.Dynamics.Nav.Server.exeSystem.ServiceModel.Channels.SocketConnection/61921478
Warning: schemas.microsoft.com/.../TraceRecord"](http://schemas.microsoft.com/2004/10/E2ETraceEvent/TraceRecord) Severity=“Warning”>msdn.microsoft.com/…/TraceIdentifier>Faulted Microsoft.Dynamics.Nav.Types.Channels.ChunkingDuplexSessionChannelMicrosoft.Dynamics.Nav.Server.exeMicrosoft.Dynamics.Nav.Types.Channels.ChunkingDuplexSessionChannel/55190699
Error: schemas.microsoft.com/.../TraceRecord"](http://schemas.microsoft.com/2004/10/E2ETraceEvent/TraceRecord) Severity=“Error”>msdn.microsoft.com/…/TraceIdentifier>Throwing an exception.Microsoft.Dynamics.Nav.Server.exeSystem.ServiceModel.CommunicationException, System.ServiceModel, Version=3.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089The socket connection was aborted. This could be caused by an error processing your message or a receive timeout being exceeded by the remote host, or an underlying network resource issue. Local socket timeout was ‘10675199.02:48:05.4775807’. at System.ServiceModel.Channels.SessionConnectionReader.GetPendingMessage() at System.ServiceModel.Channels.SessionConnectionReader.EndReceive() at System.ServiceModel.Channels.SynchronizedMessageSource.ReceiveAsyncResult.OnReceiveComplete(Object state)System.ServiceModel.CommunicationException: The socket connection was aborted. This could be caused by an error processing your message or a receive timeout being exceeded by the remote host, or an underlying network resource issue. Local socket timeout was ‘10675199.02:48:05.4775807’. —> System.IO.IOException: The write operation failed, see inner exception. —> System.ServiceModel.CommunicationException: The socket connection was aborted. This could be caused by an error processing your message or a receive timeout being exceeded by the remote host, or an underlying network resource issue. Local socket timeout was ‘10675199.02:48:05.4775807’. —> System.Net.Sockets.SocketException: An existing connection was forcibly closed by the remote host — End of inner exception stack trace — at System.ServiceModel.Channels.SocketConnection.BeginReadCore(Int32 offset, Int32 size, TimeSpan timeout, WaitCallback callback, Object state) at System.ServiceModel.Channels.SocketConnection.BeginRead(Int32 offset, Int32 size, TimeSpan timeout, WaitCallback callback, Object state) at System.ServiceModel.Channels.DelegatingConnection.BeginRead(Int32 offset, Int32 size, TimeSpan timeout, WaitCallback callback, Object state) at System.ServiceModel.Channels.PreReadConnection.BeginRead(Int32 offset, Int32 size, TimeSpan timeout, WaitCallback callback, Object state) at System.ServiceModel.Channels.DelegatingConnection.BeginRead(Int32 offset, Int32 size, TimeSpan timeout, WaitCallback callback, Object state) at System.ServiceModel.Channels.DelegatingConnection.BeginRead(Int32 offset, Int32 size, TimeSpan timeout, WaitCallback callback, Object state) at System.ServiceModel.Channels.ConnectionStream.ReadAsyncResult…ctor(IConnection connection, Byte[] buffer, Int32 offset, Int32 count, TimeSpan timeout, AsyncCallback callback, Object state) at System.ServiceModel.Channels.ConnectionStream.BeginRead(Byte[] buffer, Int32 offset, Int32 count, AsyncCallback callback, Object state) at System.Net.FixedSizeReader.StartReading() at System.Net.FixedSizeReader.AsyncReadPacket(AsyncProtocolRequest request) at System.Net.Security.NegotiateStream.StartFrameBody(Int32 readBytes, Byte[] buffer, Int32 offset, Int32 count, AsyncProtocolRequest asyncRequest) at System.Net.Security.NegotiateStream.ReadCallback(AsyncProtocolRequest asyncRequest) — End of inner exception stack trace — at System.Net.Security.NegotiateStream.EndRead(IAsyncResult asyncResult) at System.ServiceModel.Channels.StreamConnection.EndRead() — End of inner exception stack trace — at System.ServiceModel.Channels.SessionConnectionReader.GetPendingMessage() at System.ServiceModel.Channels.SessionConnectionReader.EndReceive() at System.ServiceModel.Channels.SynchronizedMessageSource.ReceiveAsyncResult.OnReceiveComplete(Object state)System.IO.IOException, mscorlib, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089The write operation failed, see inner exception. at System.Net.Security.NegotiateStream.EndRead(IAsyncResult asyncResult) at System.ServiceModel.Channels.StreamConnection.EndRead()System.IO.IOException: The write operation failed, see inner exception. —> System.ServiceModel.CommunicationException: The socket connection was aborted. This could be caused by an error processing your message or a receive timeout being exceeded by the remote host, or an underlying network resource issue. Local socket timeout was ‘10675199.02:48:05.4775807’. —> System.Net.Sockets.SocketException: An existing connection was forcibly closed by the remote host — End of inner exception stack trace — at System.ServiceModel.Channels.SocketConnection.BeginReadCore(Int32 offset, Int32 size, TimeSpan timeout, WaitCallback callback, Object state) at System.ServiceModel.Channels.SocketConnection.BeginRead(Int32 offset, Int32 size, TimeSpan timeout, WaitCallback callback, Object state) at System.ServiceModel.Channels.DelegatingConnection.BeginRead(Int32 offset, Int32 size, TimeSpan timeout, WaitCallback callback, Object state) at System.ServiceModel.Channels.PreReadConnection.BeginRead(Int32 offset, Int32 size, TimeSpan timeout, WaitCallback callback, Object state) at System.ServiceModel.Channels.DelegatingConnection.BeginRead(Int32 offset, Int32 size, TimeSpan timeout, WaitCallback callback, Object state) at System.ServiceModel.Channels.DelegatingConnection.BeginRead(Int32 offset, Int32 size, TimeSpan timeout, WaitCallback callback, Object state) at System.ServiceModel.Channels.ConnectionStream.ReadAsyncResult…ctor(IConnection connection, Byte[] buffer, Int32 offset, Int32 count, TimeSpan timeout, AsyncCallback callback, Object state) at System.ServiceModel.Channels.ConnectionStream.BeginRead(Byte[] buffer, Int32 offset, Int32 count, AsyncCallback callback, Object state) at System.Net.FixedSizeReader.StartReading() at System.Net.FixedSizeReader.AsyncReadPacket(AsyncProtocolRequest request) at System.Net.Security.NegotiateStream.StartFrameBody(Int32 readBytes, Byte[] buffer, Int32 offset, Int32 count, AsyncProtocolRequest asyncRequest) at System.Net.Security.NegotiateStream.ReadCallback(AsyncProtocolRequest asyncRequest) — End of inner exception stack trace — at System.Net.Security.NegotiateStream.EndRead(IAsyncResult asyncResult) at System.ServiceModel.Channels.StreamConnection.EndRead()System.ServiceModel.CommunicationException, System.ServiceModel, Version=3.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089The socket connection was aborted. This could be caused by an error processing your message or a receive timeout being exceeded by the remote host, or an underlying network resource issue. Local socket timeout was ‘10675199.02:48:05.4775807’. at System.ServiceModel.Channels.SocketConnection.BeginReadCore(Int32 offset, Int32 size, TimeSpan timeout, WaitCallback callback, Object state) at System.ServiceModel.Channels.SocketConnection.BeginRead(Int32 offset, Int32 size, TimeSpan timeout, WaitCallback callback, Object state) at System.ServiceModel.Channels.DelegatingConnection.BeginRead(Int32 offset, Int32 size, TimeSpan timeout, WaitCallback callback, Object state) at System.ServiceModel.Channels.PreReadConnection.BeginRead(Int32 offset, Int32 size, TimeSpan timeout, WaitCallback callback, Object state) at System.ServiceModel.Channels.DelegatingConnection.BeginRead(Int32 offset, Int32 size, TimeSpan timeout, WaitCallback callback, Object state) at System.ServiceModel.Channels.DelegatingConnection.BeginRead(Int32 offset, Int32 size, TimeSpan timeout, WaitCallback callback, Object state) at System.ServiceModel.Channels.ConnectionStream.ReadAsyncResult…ctor(IConnection connection, Byte[] buffer, Int32 offset, Int32 count, TimeSpan timeout, AsyncCallback callback, Object state) at System.ServiceModel.Channels.ConnectionStream.BeginRead(Byte[] buffer, Int32 offset, Int32 count, AsyncCallback callback, Object state) at System.Net.FixedSizeReader.StartReading() at System.Net.FixedSizeReader.AsyncReadPacket(AsyncProtocolRequest request) at System.Net.Security.NegotiateStream.StartFrameBody(Int32 readBytes, Byte[] buffer, Int32 offset, Int32 count, AsyncProtocolRequest asyncRequest) at System.Net.Security.NegotiateStream.ReadCallback(AsyncProtocolRequest asyncRequest)System.ServiceModel.CommunicationException: The socket connection was aborted. This could be caused by an error processing your message or a receive timeout being exceeded by the remote host, or an underlying network resource issue. Local socket timeout was ‘10675199.02:48:05.4775807’. —> System.Net.Sockets.SocketException: An existing connection was forcibly closed by the remote host — End of inner exception stack trace — at System.ServiceModel.Channels.SocketConnection.BeginReadCore(Int32 offset, Int32 size, TimeSpan timeout, WaitCallback callback, Object state) at System.ServiceModel.Channels.SocketConnection.BeginRead(Int32 offset, Int32 size, TimeSpan timeout, WaitCallback callback, Object state) at System.ServiceModel.Channels.DelegatingConnection.BeginRead(Int32 offset, Int32 size, TimeSpan timeout, WaitCallback callback, Object state) at System.ServiceModel.Channels.PreReadConnection.BeginRead(Int32 offset, Int32 size, TimeSpan timeout, WaitCallback callback, Object state) at System.ServiceModel.Channels.DelegatingConnection.BeginRead(Int32 offset, Int32 size, TimeSpan timeout, WaitCallback callback, Object state) at System.ServiceModel.Channels.DelegatingConnection.BeginRead(Int32 offset, Int32 size, TimeSpan timeout, WaitCallback callback, Object state) at System.ServiceModel.Channels.ConnectionStream.ReadAsyncResult…ctor(IConnection connection, Byte[] buffer, Int32 offset, Int32 count, TimeSpan timeout, AsyncCallback callback, Object state) at System.ServiceModel.Channels.ConnectionStream.BeginRead(Byte[] buffer, Int32 offset, Int32 count, AsyncCallback callback, Object state) at System.Net.FixedSizeReader.StartReading() at System.Net.FixedSizeReader.AsyncReadPacket(AsyncProtocolRequest request) at System.Net.Security.NegotiateStream.StartFrameBody(Int32 readBytes, Byte[] buffer, Int32 offset, Int32 count, AsyncProtocolRequest asyncRequest) at System.Net.Security.NegotiateStream.ReadCallback(AsyncProtocolRequest asyncRequest)System.Net.Sockets.SocketException, System, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089An existing connection was forcibly closed by the remote host at System.ServiceModel.AsyncResult.End[TAsyncResult](IAsyncResult result) at System.ServiceModel.Channels.FramingDuplexSessionChannel.EndReceive(IAsyncResult result) at System.ServiceModel.Channels.FramingDuplexSessionChannel.TryReceiveAsyncResult.CompleteReceive(IAsyncResult result) at System.ServiceModel.Channels.FramingDuplexSessionChannel.TryReceiveAsyncResult.OnReceive(IAsyncResult result) at System.ServiceModel.Diagnostics.Utility.AsyncThunk.UnhandledExceptionFrame(IAsyncResult result) at System.ServiceModel.AsyncResult.Complete(Boolean completedSynchronously) at System.ServiceModel.Channels.SynchronizedMessageSource.ReceiveAsyncResult.OnReceiveComplete(Object state) at System.ServiceModel.Channels.SessionConnectionReader.OnAsyncReadComplete(Object state) at System.ServiceModel.Channels.StreamConnection.OnRead(IAsyncResult result) at System.ServiceModel.Diagnostics.Utility.AsyncThunk.UnhandledExceptionFrame(IAsyncResult result) at System.Net.LazyAsyncResult.Complete(IntPtr userToken) at System.Net.LazyAsyncResult.ProtectedInvokeCallback(Object result, IntPtr userToken) at System.Net.AsyncProtocolRequest.CompleteWithError(Exception e) at System.Net.Security.NegotiateStream.ReadCallback(AsyncProtocolRequest asyncRequest) at System.Net.AsyncProtocolRequest.CompleteRequest(Int32 result) at System.Net.FixedSizeReader.CheckCompletionBeforeNextRead(Int32 bytes) at System.Net.FixedSizeReader.ReadCallback(IAsyncResult transportResult) at System.ServiceModel.AsyncResult.Complete(Boolean completedSynchronously) at System.ServiceModel.Channels.ConnectionStream.ReadAsyncResult.OnAsyncReadComplete(Object state) at System.ServiceModel.Channels.SocketConnection.FinishRead() at System.ServiceModel.Channels.SocketConnection.AsyncReadCallback(Boolean haveResult, Int32 error, Int32 bytesRead) at System.ServiceModel.Channels.OverlappedContext.CompleteCallback(UInt32 error, UInt32 numBytes, NativeOverlapped* nativeOverlapped) at System.ServiceModel.Diagnostics.Utility.IOCompletionThunk.UnhandledExceptionFrame(UInt32 error, UInt32 bytesRead, NativeOverlapped* nativeOverlapped) at System.Threading._IOCompletionCallback.PerformIOCompletionCallback(UInt32 errorCode, UInt32 numBytes, NativeOverlapped* pOVERLAP) System.Net.Sockets.SocketException: An existing connection was forcibly closed by the remote host2746
Error:schemas.microsoft.com/.../TraceRecord"](http://schemas.microsoft.com/2004/10/E2ETraceEvent/TraceRecord) Severity=“Error”>msdn.microsoft.com/…/TraceIdentifier>Throwing an exception.Microsoft.Dynamics.Nav.Server.exeSystem.ServiceModel.CommunicationException, System.ServiceModel, Version=3.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089The socket connection was aborted. This could be caused by an error processing your message or a receive timeout being exceeded by the remote host, or an underlying network resource issue. Local socket timeout was ‘10675199.02:48:05.4775807’. at System.ServiceModel.Channels.StreamConnection.EndRead() at System.ServiceModel.Channels.SessionConnectionReader.OnAsyncReadComplete(Object state)System.ServiceModel.CommunicationException: The socket connection was aborted. This could be caused by an error processing your message or a receive timeout being exceeded by the remote host, or an underlying network resource issue. Local socket timeout was ‘10675199.02:48:05.4775807’. —> System.IO.IOException: The write operation failed, see inner exception. —> System.ServiceModel.CommunicationException: The socket connection was aborted. This could be caused by an error processing your message or a receive timeout being exceeded by the remote host, or an underlying network resource issue. Local socket timeout was ‘10675199.02:48:05.4775807’. —> System.Net.Sockets.SocketException: An existing connection was forcibly closed by the remote host — End of inner exception stack trace — at System.ServiceModel.Channels.SocketConnection.BeginReadCore(Int32 offset, Int32 size, TimeSpan timeout, WaitCallback callback, Object state) at System.ServiceModel.Channels.SocketConnection.BeginRead(Int32 offset, Int32 size, TimeSpan timeout, WaitCallback callback, Object state) at System.ServiceModel.Channels.DelegatingConnection.BeginRead(Int32 offset, Int32 size, TimeSpan timeout, WaitCallback callback, Object state) at System.ServiceModel.Channels.PreReadConnection.BeginRead(Int32 offset, Int32 size, TimeSpan timeout, WaitCallback callback, Object state) at System.ServiceModel.Channels.DelegatingConnection.BeginRead(Int32 offset, Int32 size, TimeSpan timeout, WaitCallback callback, Object state) at System.ServiceModel.Channels.DelegatingConnection.BeginRead(Int32 offset, Int32 size, TimeSpan timeout, WaitCallback callback, Object state) at System.ServiceModel.Channels.ConnectionStream.ReadAsyncResult…ctor(IConnection connection, Byte[] buffer, Int32 offset, Int32 count, TimeSpan timeout, AsyncCallback callback, Object state) at System.ServiceModel.Channels.ConnectionStream.BeginRead(Byte[] buffer, Int32 offset, Int32 count, AsyncCallback callback, Object state) at System.Net.FixedSizeReader.StartReading() at System.Net.FixedSizeReader.AsyncReadPacket(AsyncProtocolRequest request) at System.Net.Security.NegotiateStream.StartFrameBody(Int32 readBytes, Byte[] buffer, Int32 offset, Int32 count, AsyncProtocolRequest asyncRequest) at System.Net.Security.NegotiateStream.ReadCallback(AsyncProtocolRequest asyncRequest) — End of inner exception stack trace — at System.Net.Security.NegotiateStream.EndRead(IAsyncResult asyncResult) at System.ServiceModel.Channels.StreamConnection.EndRead() — End of inner exception stack trace — at System.ServiceModel.Channels.StreamConnection.EndRead() at System.ServiceModel.Channels.SessionConnectionReader.OnAsyncReadComplete(Object state)System.IO.IOException, mscorlib, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089The write operation failed, see inner exception. at System.Net.Security.NegotiateStream.EndRead(IAsyncResult asyncResult) at System.ServiceModel.Channels.StreamConnection.EndRead()System.IO.IOException: The write operation failed, see inner exception. —> System.ServiceModel.CommunicationException: The socket connection was aborted. This could be caused by an error processing your message or a receive timeout being exceeded by the remote host, or an underlying network resource issue. Local socket timeout was ‘10675199.02:48:05.4775807’. —> System.Net.Sockets.SocketException: An existing connection was forcibly closed by the remote host — End of inner exception stack trace — at System.ServiceModel.Channels.SocketConnection.BeginReadCore(Int32 offset, Int32 size, TimeSpan timeout, WaitCallback callback, Object state) at System.ServiceModel.Channels.SocketConnection.BeginRead(Int32 offset, Int32 size, TimeSpan timeout, WaitCallback callback, Object state) at System.ServiceModel.Channels.DelegatingConnection.BeginRead(Int32 offset, Int32 size, TimeSpan timeout, WaitCallback callback, Object state) at System.ServiceModel.Channels.PreReadConnection.BeginRead(Int32 offset, Int32 size, TimeSpan timeout, WaitCallback callback, Object state) at System.ServiceModel.Channels.DelegatingConnection.BeginRead(Int32 offset, Int32 size, TimeSpan timeout, WaitCallback callback, Object state) at System.ServiceModel.Channels.DelegatingConnection.BeginRead(Int32 offset, Int32 size, TimeSpan timeout, WaitCallback callback, Object state) at System.ServiceModel.Channels.ConnectionStream.ReadAsyncResult…ctor(IConnection connection, Byte[] buffer, Int32 offset, Int32 count, TimeSpan timeout, AsyncCallback callback, Object state) at System.ServiceModel.Channels.ConnectionStream.BeginRead(Byte[] buffer, Int32 offset, Int32 count, AsyncCallback callback, Object state) at System.Net.FixedSizeReader.StartReading() at System.Net.FixedSizeReader.AsyncReadPacket(AsyncProtocolRequest request) at System.Net.Security.NegotiateStream.StartFrameBody(Int32 readBytes, Byte[] buffer, Int32 offset, Int32 count, AsyncProtocolRequest asyncRequest) at System.Net.Security.NegotiateStream.ReadCallback(AsyncProtocolRequest asyncRequest) — End of inner exception stack trace — at System.Net.Security.NegotiateStream.EndRead(IAsyncResult asyncResult) at System.ServiceModel.Channels.StreamConnection.EndRead()System.ServiceModel.CommunicationException, System.ServiceModel, Version=3.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089The socket connection was aborted. This could be caused by an error processing your message or a receive timeout being exceeded by the remote host, or an underlying network resource issue. Local socket timeout was ‘10675199.02:48:05.4775807’. at System.ServiceModel.Channels.SocketConnection.BeginReadCore(Int32 offset, Int32 size, TimeSpan timeout, WaitCallback callback, Object state) at System.ServiceModel.Channels.SocketConnection.BeginRead(Int32 offset, Int32 size, TimeSpan timeout, WaitCallback callback, Object state) at System.ServiceModel.Channels.DelegatingConnection.BeginRead(Int32 offset, Int32 size, TimeSpan timeout, WaitCallback callback, Object state) at System.ServiceModel.Channels.PreReadConnection.BeginRead(Int32 offset, Int32 size, TimeSpan timeout, WaitCallback callback, Object state) at System.ServiceModel.Channels.DelegatingConnection.BeginRead(Int32 offset, Int32 size, TimeSpan timeout, WaitCallback callback, Object state) at System.ServiceModel.Channels.DelegatingConnection.BeginRead(Int32 offset, Int32 size, TimeSpan timeout, WaitCallback callback, Object state) at System.ServiceModel.Channels.ConnectionStream.ReadAsyncResult…ctor(IConnection connection, Byte[] buffer, Int32 offset, Int32 count, TimeSpan timeout, AsyncCallback callback, Object state) at System.ServiceModel.Channels.ConnectionStream.BeginRead(Byte[] buffer, Int32 offset, Int32 count, AsyncCallback callback, Object state) at System.Net.FixedSizeReader.StartReading() at System.Net.FixedSizeReader.AsyncReadPacket(AsyncProtocolRequest request) at System.Net.Security.NegotiateStream.StartFrameBody(Int32 readBytes, Byte[] buffer, Int32 offset, Int32 count, AsyncProtocolRequest asyncRequest) at System.Net.Security.NegotiateStream.ReadCallback(AsyncProtocolRequest asyncRequest)System.ServiceModel.CommunicationException: The socket connection was aborted. This could be caused by an error processing your message or a receive timeout being exceeded by the remote host, or an underlying network resource issue. Local socket timeout was ‘10675199.02:48:05.4775807’. —> System.Net.Sockets.SocketException: An existing connection was forcibly closed by the remote host — End of inner exception stack trace — at System.ServiceModel.Channels.SocketConnection.BeginReadCore(Int32 offset, Int32 size, TimeSpan timeout, WaitCallback callback, Object state) at System.ServiceModel.Channels.SocketConnection.BeginRead(Int32 offset, Int32 size, TimeSpan timeout, WaitCallback callback, Object state) at System.ServiceModel.Channels.DelegatingConnection.BeginRead(Int32 offset, Int32 size, TimeSpan timeout, WaitCallback callback, Object state) at System.ServiceModel.Channels.PreReadConnection.BeginRead(Int32 offset, Int32 size, TimeSpan timeout, WaitCallback callback, Object state) at System.ServiceModel.Channels.DelegatingConnection.BeginRead(Int32 offset, Int32 size, TimeSpan timeout, WaitCallback callback, Object state) at System.ServiceModel.Channels.DelegatingConnection.BeginRead(Int32 offset, Int32 size, TimeSpan timeout, WaitCallback callback, Object state) at System.ServiceModel.Channels.ConnectionStream.ReadAsyncResult…ctor(IConnection connection, Byte[] buffer, Int32 offset, Int32 count, TimeSpan timeout, AsyncCallback callback, Object state) at System.ServiceModel.Channels.ConnectionStream.BeginRead(Byte[] buffer, Int32 offset, Int32 count, AsyncCallback callback, Object state) at System.Net.FixedSizeReader.StartReading() at System.Net.FixedSizeReader.AsyncReadPacket(AsyncProtocolRequest request) at System.Net.Security.NegotiateStream.StartFrameBody(Int32 readBytes, Byte[] buffer, Int32 offset, Int32 count, AsyncProtocolRequest asyncRequest) at System.Net.Security.NegotiateStream.ReadCallback(AsyncProtocolRequest asyncRequest)System.Net.Sockets.SocketException, System, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089An existing connection was forcibly closed by the remote host at System.ServiceModel.Channels.SessionConnectionReader.GetPendingMessage() at System.ServiceModel.Channels.SessionConnectionReader.EndReceive() at System.ServiceModel.Channels.SynchronizedMessageSource.ReceiveAsyncResult.OnReceiveComplete(Object state) at System.ServiceModel.Channels.SessionConnectionReader.OnAsyncReadComplete(Object state) at System.ServiceModel.Channels.StreamConnection.OnRead(IAsyncResult result) at System.ServiceModel.Diagnostics.Utility.AsyncThunk.UnhandledExceptionFrame(IAsyncResult result) at System.Net.LazyAsyncResult.Complete(IntPtr userToken) at System.Net.LazyAsyncResult.ProtectedInvokeCallback(Object result, IntPtr userToken) at System.Net.AsyncProtocolRequest.CompleteWithError(Exception e) at System.Net.Security.NegotiateStream.ReadCallback(AsyncProtocolRequest asyncRequest) at System.Net.AsyncProtocolRequest.CompleteRequest(Int32 result) at System.Net.FixedSizeReader.CheckCompletionBeforeNextRead(Int32 bytes) at System.Net.FixedSizeReader.ReadCallback(IAsyncResult transportResult) at System.ServiceModel.AsyncResult.Complete(Boolean completedSynchronously) at System.ServiceModel.Channels.ConnectionStream.ReadAsyncResult.OnAsyncReadComplete(Object state) at System.ServiceModel.Channels.SocketConnection.FinishRead() at System.ServiceModel.Channels.SocketConnection.AsyncReadCallback(Boolean haveResult, Int32 error, Int32 bytesRead) at System.ServiceModel.Channels.OverlappedContext.CompleteCallback(UInt32 error, UInt32 numBytes, NativeOverlapped* nativeOverlapped) at System.ServiceModel.Diagnostics.Utility.IOCompletionThunk.UnhandledExceptionFrame(UInt32 error, UInt32 bytesRead, NativeOverlapped* nativeOverlapped) at System.Threading._IOCompletionCallback.PerformIOCompletionCallback(UInt32 errorCode, UInt32 numBytes, NativeOverlapped* pOVERLAP) System.Net.Sockets.SocketException: An existing connection was forcibly closed by the remote host2746
goto C:\Program Files (x86)\Microsoft Dynamics NAV\60\Service-1 and C:\Program Files (x86)\Microsoft Dynamics NAV\60\Service-2 and check, if the settings are correct in the file(s) CustomSettings.config.
the restart the nav service(s).
