Web service Deployment error in AX 2012
I am working in AX 2012,when i am deploying service group i am facing the following issue.
The port ‘ProjectIdImportServiceGroup’ could not be deployed.\nError:
c:\Users\Administrator\AppData\Local\Temp\ServiceGeneration\PROJECTIDIMPORTSERVICE.cs(34,19) : error CS0234: The type or namespace name ‘ProjectIdImportService’ does not exist in the namespace ‘Dynamics.Ax.Application’ (are you missing an assembly reference?)
c:\Users\Administrator\AppData\Local\Temp\ServiceGeneration\TBL_PROJECTIDIMPORTSERVICE.cs(34,66) : error CS0234: The type or namespace name ‘ProjectIdImportService’ does not exist in the namespace ‘Dynamics.Ax.Application’ (are you missing an assembly reference?)
Please share your ideas to solve the issue.
It means that ProjectIdImportService class doesn’t exist in CIL code. Please generate CIL before continuing.
HI Martin,
Thank you for your reply.
I have generated Full CIL and Incremental CIL in twice. But the problem not resolved.
Well, the class is definitely not there by some reason (“The type or namespace name ‘ProjectIdImportService’ does not exist in the namespace ‘Dynamics.Ax.Application’”). Didn’t you get any errors when generating CIL?
Raman Kutala
Right click yr servicegroup name and deploy
and then go and check inbound
please understand my problem, when i doing deploy of my service group i am facing issue.
Hi Martin,
Thank you for your reply, the problem is solved. Basically, this problem is occurred when the web services are imported into other machine. The importing was not done properly, so I removed the service group and imported once again, then the problem is solved.
Thank you
Raman Kutala.
