Hi, Is it correct that the web deployment does not install the configuration utility? The service pack will not install, i referred to it with the serverservicepack line ( i tried referring to the directory and to setup.exe) Thanks in advance
Hi, Yes - If configured correctly, NAWDC will configure Axapta clients as well. Navision Axapta Web Deployment Client (NAWDC) is meant both for easy deployment and configuration of Axapta client using Internet/Intranet. I don’t remember the exact property where you have to specify the configuration. But I would suggest you to refer to the Web Deployment document that came along with Axapta 3.0 CD. Regards, Harish Mohanbabu
Hi, in the Axpata 3.0 SP3 Webdeployment CAB-File, the AxConfiguration Utility is now included and will be installed. Alex
