warehouse setup
hi everyone…
i need a small clarification on the warehouse setup…the fields on the warehouse setup and the fields on the warehouse tab of the location card such as require receive, require shipment, require pick, require putaway…etc are same…can u explain me the difference between the both the setups…and if so wat is that…and which is mandatory…ur reply wuld be appreciable…
Hi Satya
From your recent posts I will gather you are trying to learn the software. I would recommend you attend some courses. Whilst asking questions here may get you some answers you really need to learn and understand the software properly. You can set it up and then ask these sorts of questions, you can even post through examples (I do not believe you are from the questions) and this will all help. But either getting manual lead training, or tuition from a colleague, or attending the standard courses will only benefit you.
You sould also use the search facililty on this site, as I answered this question recently. The fields you refer to are used where you have a warehouse setup and no location cards.
thanks for ur reply…
i hav setup the location card with all the fields on the warehouse tab…i got the usage of each field…but i didnt got the usage of fields on the warehouse setup…so can u explain that in detail for only warehouse setup with any example…ur reply wuld be appreciable…
satya…
Imagine you have NO location cards.
Now set the system up to pick and receive.
