anybody can share DAX warehouse management material
Thanks in advance
siddu
Thanks in advance
siddu
Hi Siddu,
Which version your looking at ? AX 2009 or AX 2012 ??
By the way, share your mail ID.
Hi Sarathy
thank u so much…
regards
siddu
I’ve forwarded doc. Check your Email-ID
I would suggest you download the latest from partnersource/customersource. If you do not have access then MS believe you should not get the material.
According to me, both are AX 2009 and AX 2012 versions are good to use and your choice is perfect. Good luck.
Hello! I am new to dynamics. can anyone help me how to start implementing HR in DAX 2012
