There are a number of possiblities. The easiest to explain is to use a Integer loop. Declare the comments and sales line as record variables and filter them to the order needed. Set the range on the number field to be the bigger COUNT of the filtered record variables. Then in the loop print the values from the record variable.
I have tried this ?. But still it is not working.if the record lines are less than 5 then it is showing in first page only.Otherwise the lines are going in the second page.
I have only header and body sections of Sales Header, Sales Line and integer.I have Shortened the section width but still the lines are showing in second page onwards.The first page is showing only header part.
