I have a problem following the steps of the walkthrough. It is on the Command Prompt part wherein the SC fails to create a new Serveer Instance. It says that [SC] SCManager create failed 1772.
Can you give me some suggestions on how to solve this error?
Thanks.
Welcome to DUG [:)]
Are you by any chance doing it via remove desktop?
Hi ,
You can use following link to create multiple services.
http://www.mibuso.com/dlinfo.asp?FileID=1348
Thank you for the greeting Mohona…
What do you mean by remove desktop?
Hi Amol,
The link that you gave to me is an application. Am I right?
Is there any links or websites that I can search for the procedure on how to access multiple database of the same RTC?
Thanks a lot guys for your replies.
