Quick question:- We have a client that needs the ability to store large amount of texts in a table. So WaldoPad seems to be a perfect fit. I am just having issues installing it on their server. Client Setup: 1 NAV Server 10 additional server that connect to the nav server. These 10 servers are used to do load balancing. I installed (by running the the WaldoNavPad Setup.msi file) Waldopad on 1 of the 10 server to test it out and I imported the objects but I keep getting the error message–> “Please run the setup of WaldoNavPad”. I also tried restarting the server and I still keep getting the same error message. So the next logical setup is to install it on the NAV Server. Can someone guide me as to what I need to do in order to get past the error message. Getting waldopad to work is a key component of the module that I am working on. Am I missing something crucial? Or would installing it on NAV Server should fix it. And after installing it on NAV Server would I have to restart it??
did you get this to work? You didnt mention what version of NAV and WaldoNAv pad you are installing, as well as if the NAV clients are RTC or Classic.
Have you tried manually registering the dll?
