VPN connection
Hi all, I have setup a client in the US who is connecting to our UK networks via VPN. I am stumped as to what settings I put in the open database dialogue though[?] Do I just enter the name of the server in the “server name”? or do I have to enter some sort of path? I initially tried the server name but it keeps telling me “unable to find the server” VPN is certainly connected. Any ideas?
Unless you have a very fast connection, you will need to use either Citrix or Terminal Server. You can connect directly, but it will not be the fastest solution. In this case, (assuming your VPN is setup and logged in correctly,) just enter the navision Server IP address as normal.
