Example - Created and Post to Invoice a Purchase Order with a dimension “Department - A”
Posted a check payment for the invoice but with a wrong dimension of “Department - B”
so when i tried to reverse the transaction by simply going to check ledger entry then “Void and Unapply” the check, i notice that the entries made on the G/L entries after i voided and un-applied the check listed extra g/l entries that made my G/L analysis by dimension still has a floating entry on it.
NAV made an opposite entry in GL to balance out the voided check - by design NAV can’t create STORNO entries in such cases.
Balance is OK, but turnover is increased - if you want/need to get rid of excess turnover, you must manually create minus Db & minus Cr entries in GL Journal and post them.
That will be even more entries, but there is no other way as NOTHING can be simply deleted once posted - all corrections must be done by reversing entries. This is a legal requirement for all ERP systems and conforms with general accounting rules.
Same scenario happened on our company, we’re using NAV2013R2 version as well.
Posted Purchase Invoice No: PPI-0001
Dimensions encoded on Posted Purchase Invoice:
Department: A
Project: A
Payment with the application of PPI-0001
Dimensions encoded on payment journal:
Department: A
Project: B
Since, the dimension from the payment journal was wrong. I have to void and unapply the check on back account-check ledger entries. But when I voided and unapplied the check, it created entries for ‘voided check’ and ‘unapplication’. Now, when I analyze G/L by Dimension, there is a floating AP balance for dimension B.
Is there any way to remove the unapplication entries or workarounds on how to avoid the entry of unapplication.
