Dear all,
Following error message(event log) occoured at the time of Nav 2009 SP1 installation .
=== Logging started: 2009/11/09 15:27:57 ===
Executable: E:\Navision 2009 SP1\setup.exe v6.0.29626.0
Computer : ADMIN-PC
— logging level: standard —
RegistrySearch: Searching for registry key value. Id = ‘DotNetFx35SpLevel’
RegistrySearch: Searching for registry key value. Id = ‘DotNetFx35Installed’
RegistrySearch: Searching for registry key value. Id = ‘DotNetFx35Chart’
RegistrySearch: Checking registry key existence. Id = ‘ReportVwr2008’
RegistrySearch: Checking registry key existence. Id = ‘SQLEXPR2005’
RegistrySearch: Checking registry key existence. Id = ‘VisualJ20’
RegistrySearch: Checking registry key existence. Id = ‘MsXml60’
RegistrySearch: Checking registry key existence. Id = ‘BizzTalk’
RegistrySearch: Checking registry key existence. Id = ‘Outlook’
RegistrySearch: Searching for registry key value. Id = ‘VCPPSpLevel’
RegistrySearch: Checking registry key existence. Id = ‘VCPPInstalled’
RegistrySearch: Checking registry key existence. Id = ‘SqlDbInstalled’
Configuring MSI package. Id = ‘ARP’
MSI log file set to: C:\Users\admin\AppData\Local\Temp\setup.wix.msi.9.log
Done configuring MSI package. ReturnCode = 0
Configuring EXE package. Id = ‘SQLEXPR2005’
Done configuring EXE package. ReturnCode = 18456
Rolling back MSI package. Id = ‘ARP’
MSI log file set to: C:\Users\admin\AppData\Local\Temp\setup.wix.msi.a.log
Done rolling back MSI package. ReturnCode = 0
ERROR: Package Microsoft SQL Server 2005 Express failed with error. See detailed message above.
=== Logging stopped: 2009/11/09 15:31:51 ===
Microsoft Dynamics NAV 2009 Installation Report
Microsoft Dynamics NAV 2009 Build 29626
Error Report
Setup Components
The component was rolled back.
Package failed to install.
What is the solution of this issue ?
