Visio diagramm
Does anybody have expierience to draw entity relationship diagramm in Visio through odbc access to navision database? I just can retrieve entity but relationships.Is it really possible?
You’ve got in www.mynavision.net something that may help you. Instead of using ODBC to navision database, it uses Automations for creating the Visio models. Have a look in the downloads area: Visio Data Modeller. http://213.224.78.194:38001/navision/dl.asp?Filename=visiodatamodeler.zip – Alfonso Pertierra apertierra@teleline.es Spain
if i choose type of object:tables and range of object IDs-then i just can see diagram that show entity and existance of relationship between them without detalization on field level.Is it possible to be more deep?
I know of the ODBC functionality in Visio, and on a Access database for instance it is working fine. Unfortunately the ODBC driver for Navision still has some way to go, before you can use for advanced tasks. Lets hope the day will come… Soren Nielsen, moderator Integration/Developer NOLUG
Hi, I need visio shema diagrams of navision 2009… please share with my!! or tell me how can get!
You can look at www.navitools.com. They have some diagrams, but I’m not sure how up to date they are or what versions they’ve done.
