Visible grid records to report
Hi
I need to make my own report from this what is visible in grid. I would like to do something like autoraport but with my own (another in autoraport) columns. I now i can change the autoraport columns - but it will not resolve my problem. I want report which will show only this column which is show in grid - i have an idea how to do it.
But how to catch the actual visible records from grid?
To show records i can use the query which is build when I open the form. This work good.
But how to catch the actual visible records from grid when they was filtered? << This my question.
Thx from all advice
In another side - may You know how to catch this string - which user write in find value (shortcut on form) ??
This could resolve my previous problem…
OK. the problem was resolved.
Simple I need to catch QueryRun and send it as parmeter to my raport
If someone looking for - the code :
run = ClassFactory.reportRunClass(new Args(“Test”));
run.init();
run.queryrun(qr).interactive(false);
run.queryRun(qr);
run.run();
Test it’s my report, qr is QueryRun object = QueryRun from form.
