Visibility of a value using Display Method
I want to control the visibility of a value in a column in my report using the display method.
what I did is this:
display Str bsxEmplName()
DirPartyTable dirPartyTableLocal;
EmplTable emplTableLocal;
if(emplTableLocal.EmplId != ‘’)
return dirPartyTableLocal.Name;
return ‘’;
What I want is that the value(or the name from the DirPartyTable) should be visible if EmplId from the EmplTable has a value.
Use like this .
If(empITableLocal.EmplIe!=’’) then
Currreport.controlname.visible=true;
Thanks for your help… but I already solved it… thanks again :slight_smile:
