hi , i have a table named “testcases”,which has only one field(string). for example if i have entered 3 entries in this testcases table say, value 1,value 2,value 3. in another for i want to view all these 3 entries one below the other with a option of checking and unchecking the value1,value2,value3…how to do it?
Can you explain in detail???
Hi Rajee,
If your not getting Values for GOTOMainTable
Check this link to work with go to main Table with XPO.
http://axhelper.blogspot.com/2011/02/how-to-get-main-tableform-from-another.html
So you are not getting all the values in the form…Check if any filters or ranges are added to it…
