Hello.
When making the team foundatation server version-control “enabled”
(Tools → Development tools - > setup → parameters → Version control)
and pressing OK, I got the message :
Team Foundation Server Error
Value cannot be null.
Parameter name: projectName
Any clue about the reason for the problem?
It’s on standard class :
SysVersionControlFilebasedBackEndTfs::processTfsException
on line : error(errorMessage);
Hi.
When you select TFS as version control system you get a second tab on your form in which you have to enter the TFS server name and the project name. Can you check if you have setup correctly these?
