I have read a lot of threads about UOM and variants but haven’t been able to answer this question for myself. Maybe because it’s midnight but I just can’t get this to work. The scenario:
I buy a chemical (lot-tracked) which I stock and consume in grams. I have 2 suppliers and each sells it in 2 different size bottles: 2kg and 10kg. Prices for each size are different and each has it’s own vendor item number.
I have set it up this way:
Base unit=g. My purchase units have to be Kg since there are multiple sizes of container.
The Item Card for the chemical has 2 variants based on the volume of the container, 2K and 10K. I had to add new units of measure to the item card for each variant so that I could order the containers in the vendor’s handling unit (each.) Whether I want to buy 2 kg or 10 kg, my order quantity still has to be 1, right?
This all works pretty well. When I create a PO for Vendor/Item/Variant, the direct costs all come up correctly. Yay.
Problem: I also need the vendor’s item # for each item/variant to come onto the PO line. The only means I can find to do this is to create a SKU card. But there seems to be a 1:1 correlation between SKUs and variants. I cannot get NAV to generate a SKU card for different vendors and the same variant code.
I am missing a critical bit of understanding here. I suppose I could have the purchaser fill the vendor item number in manually but that stinks. It seems like this should work.
Teach me the ways, great shamans.
