Vendor PDC
Hi All
Environment: Ax 2012 R2 CU6
I am trying to post the Vendor PDC on the maturity date by using the button the settle clearing entries and i am getting the error message cannot create a record in ledger journal table. Record already exists. I even tried to map the new number sequence for the journal batch number and voucher series of that journal and also tried to remove the property continuous but still the same message pops up
Anandh
Are you facing this issue after applying CU6 ?
I have not applied CU6, original installation was that configuration
Please check, if this isn’t your issue http://www.kaya-consulting.com/ax2012-r2/solve-continuous-number-sequence-issue-in-ax-2012-r2/
