I am not getting the vendor in the Planned proporsal .
I have already defined the trade agreement
and Selected the rule for vendor selection in MAster planning parameter (planned orders tab )as (minimun lead time one time & other time as minimumn price…also tried after ON / Off “find trade agreement”
What rule do you want it to obey? If you define a default vendor it appears, then you have to remove it to get TA’s to work, but you also need to look at item coverage settings and the impact here.
First you must NOT have a default vendor, then you set the supplier trade agreement, create one and then configure master planning to look at trade agreements - get one to come in first. As it is two versions ago there could easily be problems with this as well, my memory does not go that far back I am afraid.
