VB and XML Encoding (UTF-8) to MSMQ :Integration to Navision 5.0 SP1
Guys…I really need your help… I have this vb code where i will send a value typed in a textbox to MSMQ…and NAS is successfully started with startup parameter ‘WEBSERVICE’ and the test c/al code susccessfully run within Navision in Codeunit 1 (trigger 99)…it’s just that the integration part is failed…
C/AL CODE
Documentation()
OnRun()
CREATE(MQBus);
CREATE(CC2);
CREATE (XMLDom);
CC2.AddBusAdapter(MQBus,1);
MQBus.OpenReceiveQueue(’.\toNavision’,0,1);
//BEGIN
//synic.INIT;
//synic.Alamat := ‘kg baru’;
//synic.Fon := ‘9876655’;
//synic.Rumah := ‘banglo’;
//synic.INSERT;
//END;
CC2::MessageReceived(VAR InMessage : Automation “’’.IDISPATCH”)
// get the message
InMsg := InMessage;
InS := InMsg.GetStream();
// load the message into an XML document and find a node
XMLDom.load (InS);
XMLNode := XMLDom.selectSingleNode (‘string’);
// open the response queue and create a new message
MQBus.OpenWriteQueue(’.\fromNavision’,0,1);
OutMsg := CC2.CreateoutMessage(‘Message queue://.\fromNavision’);
OutS := OutMsg.GetStream();
// build the contents of your message
XMLNode.text := UPPERCASE (XMLNode.text);
// fill the message and send it
OutS.WRITE(XMLDom.xml);
OutMsg.Send(0);
VB CODE
Protected Sub Button1_Click(ByVal sender As Object, ByVal e As System.EventArgs) Handles Button1.Click
Dim mq As MessageQueue
'Dim format As XmlMessageFormatter
Dim msg As Message
'Dim dec As XmlDeclaration
Try
msg = New Message
msg.Priority = MessagePriority.Normal
If Not (MessageQueue.Exists(".\Private$\toNavision")) Then
mq = MessageQueue.Create(".\Private$\toNavision")
Else
mq = New MessageQueue(".\Private$\toNavision")
End If
msg.Label = “Navision MSMQ-BA”
msg.Body = TextBox1.Text
mq.Send(msg)
Label1.Text = “Message sent.”
Catch ex As MessageQueueException
Label1.Text = ("MSMQ Error: " + ex.ToString())
Catch ex As Exception
Label2.Text = ("Error: " + ex.ToString())
Finally
mq.Close()
End Try
End Sub
And the result is successful…where by I can see the message in the queue…
but i’m not sure of the XML encoding…and i need to send the message in UTF-8, furthermore i can’t figure out how to send those message to be UTF-8 into the Queue… Please help…
Your message queue must be private and non-transactional. The message queue’s AD integration must be turned off. Also, I believe someone posted that the MQBA doesn’t work on 64 bit.
By the way, pasar malam means busy evening right? I used to live in Holland and they had this market every year called ‘pasar malam besar’ and some told me that means busy evening market. The only other thing I remember is selamat makan and trima kasi, but I probably spelled that wrong :).
In your VB Code use MSDOM DLL file and load
MSDOM.load(TextBox1.Text);
msg.Body = MSDOM;
In Textbox1.Text You need to include the following in your xml tag.
? xml version=“1.0” encoding=“utf-8” ?
XMDOM will then encodde it in UTF-8
Guys…I’m very new to Navision and never done any system integration…my knowledge currently is limited…so bear with me if i ask more questions…i take this as a challenge to myself n see how far i can go actually
DenSter, u r right about the ‘pasar malam’ [:D]…glad to hear that u at least remember the country…
my queue is private and non-transactional and the queue is not published to AD…everything are running on my local…n my machine is 32 bit…
Rashed Amini
i dont quite understand the code…but i’ll try to find out about it…thanks [:D]
