Good question. In Business Central, keeping the VAT setup usually won’t cause issues, even for Canadian companies. The key is to make sure:
Posting setups are mapped correctly.
VAT isn’t applied by default in local transactions.
Codes you don’t need are disabled or avoided.
Some companies keep VAT active for occasional international transactions, and it works fine if managed carefully. So yes, technically possible and practically doable, it might work for you as it worked for us.
