HeHello am trying to use the “variable scrap” function in the item, in order to drive the system to assume a certain percentage of scrap for that item. In essence, I want the planned purchase orders to increase due to an assumed ongoing scrap loss. But so far it has not worked. Is there a master setting somewhere that may need to be turned on for this functionality to work?
Hi Jason,
How did you specify the variable scrap? Did you do it on the item lines or on the production bom?
