values of array in dubug mode
Hi How to view values in array while debugging. I am able to view the value of tables by using zoom . But in the case of array I can only view the name of array. Please help Regards Joseph Mathew
The only way of seeing array values for debugging is using messages or copying the value of the actual element of the array you’re wanting to see to a variable, as the debugger don’t let you inspecting the array valuese directly. – Alfonso Pertierra apertierra@teleline.es Spain
Yeah, seeing the content of arrays in debugging is a wish many developers had before you. Little chance, though, the wish will be fulfilled on short notice… A workaround I’m using now and then, is putting a number of textboxes on the form (report) with the array elements as source. Not very elegant, but workable. John
