Values changed after Navision Backup
Dear All, I currently have a client running Navision 3.60 (SQL) on a W2k server. They have 5 companies set up within the database, which the current size is 14GB. A very normal setup. They use the Navision Backup at a periodic time for individual companies for development/testing purposes. Otherwise they do a SQL backup on a daily basis. There was this strange phenomenan… whenever they do a Navision Backup (not SQL Backup), all the value of a particular field in a table (Service Item - Unit of Measure Code) gets overwritten with a value from the Item Unit of Measure Table. The value is not always the same too! Not sure whether it happens to other tables/fields as well. Have you ever seen anything similar? Do you have any suggestions to where I should look into to find a way to stop this from happening? Any help will be greatly appreciated. Thanks a lot!
Hi, Please have all the users log out while taking a backup. Though Navision cliams that user need not log out while taking a Navision backup, i have seen couple of issues happening to the backup while users are logged on to the database. Thanks Best regards Suresh.
