when i open value entry table or a form based on value entry…its performance is ok
but when i open it from item card ( Item - Entries - values entries)… the value entry form hang up… i try to check behind the scene… its filtering by item number and sorting by item number.
Amer is correct, the problem is that you haven’t specified the right key. Even though you haven’t modified the code then this might happen especially if the calling card is using specific filters.
What version are you using and do you have the same problem from all users?
