hi,
I created a new website for workflow. I can browse the website in IIS 6. but i cant validate or browse outside (from browser).
it shows “http:404 file or directory not found” error. Website URL is http://:85/Workflowsite
please any one help.
hi,
Hi Dpsan,
I think you need to check the “path” that you have given is correct…
Thanks lilly… but i checked the path…
http://servername:port/sitename
m using port 85 other than 80…
Hi Dpsan,
Did you give this winAPI::shellExecute(url); after you code.
If you don’t mind can you please Share your Code?
Lilly,
sorry, m not using via code. m just created website in IIS 6 for workflow. and trying to validate the URL in workflow infrastructure configuration wizard. Thanks for your reply
