I agree with the blocked field solution… the question here is will the client accept it? you know how some of the clients are, just plain demanding
Hi Guys, If you have 7 mandatory fields for this then you will have to check each of this field each time a user blocks or unblocks the item. And if some of this fields are look-ups like the inventory posting group then coding for all the exceptions is tedious. Although, the solution is acceptable. Some possible results are: 1. THe user create a New Item and does not enter the Mandatory Fields. He tries to create a new item card again so you can have a duplication problem. 2. If you blocked and have a running number series then you will loose a Number. If prem’s customer at this point does not have a running number but can always choose to do it. So suggestion is to validate before inserting and not after inserting.
