I have one table with three fields Code, fromWeight and toWeight.
I want a validation in order to prevent overlapping of fromWeight and Toweight range.
Please Help.
Please Help.
hello moumita
Why dont you use validateField method.
Hi kumar,
Since the validation depends on two field , so validate field will not work properly.
I have used validate write as follows :
public boolean validateWrite()
boolean ret;
NIM_ItemWeightBucket ItemWtBucket1,ItemWtBucket2,ItemWtBucket3,ItemWtBucket4,ItemWtBucket5;
real i,j,k;
ret=true;
if(this.Symbol=="")
ret=checkFailed(“Set default Unit ID in invent parameter”);
else
while select ItemWtBucket1
for(i=this.FromWeight;i<=this.ToWeight;i=i+0.01)
j=ItemWtBucket1.FromWeight;
select count(RecId) from ItemWtBucket2 where (ItemWtBucket2.FromWeight==i || ItemWtBucket2.ToWeight==i);
if(ItemWtBucket2.RecId>0)
if(k==0)
ret=checkFailed("This range already exists/ Range overlaping not allowed ");
k++;
break;
return ret;
But it may not be correct way to solve the purpose, so that I have asked you all if any one could give me a right solution.
Hello Das
check below code it will use to you.
public boolean validateField(fieldId _fieldIdToCheck)
boolean ret;
ret = super(_fieldIdToCheck);
switch (_fieldIdToCheck)
case fieldNum(tutorial_Form_DynaLink2 [tablename],field2 [fieldname]):
if (this.Field2<this.Field1)
ret = checkFailed("@GLS62531");
break;
return ret;
If issue was toweight not less than fromweight
Hi Moumita,
I hope the following code will solve ur issue in a simple way. Write this code in validateWrite method of the table.
select minof(fromWeight), maxof(toWeight) from tableName where tableName.RecId != this.RecId;
if (this.low < tableName.fromWeight && this.high < tableName.fromWeight)
ret = true;
else if (this.low > tableName.toWeight&& this.high > tableName.toWeight)
ret = true;
else
ret = checkFailed(“Values overlapping”);
replace this.low and this.high by this.fromWeight and this.toWeight…
Hi Faisal Raja,
Now it’s working fine. Thanks a lot.
Welcome [:)]
