Validate Dataport before importing
When journal lines data are imported using dataport, some of the validation errors occurs so each time they have to go back to the flat file and do the required changes and import again, if they have so many validation issue they wants to correct it in one time.
Like when they import dataport, if any error found flat file, one form has to be populated and should show all the issues in the flat file, then user can able to correct it in the form and update journal line. like rapid start services data migration.
How to achieve this in NAV 2009, any suggestion appreciated. Thanks
Shyam
Hi
So why not use data migration tool and excel file instead?
Neil
Hi Neil,
Thanks for your reply, Actually they import general journal lines using data port, the file contains more than 300 lines when they try to upload the file, they come across validation issues with file data and journal lines, each time they go back to the file and do the necessary change to upload again,
So they need those issues to be shown in a separate form, then if any error in upload file they will change it in that form and upload. please give some suggestion.
Shyam
