Is is possible examine a licence file directly and determine the object ranges that customer has access to?
Hi I dont think so you can do that, but usually NSC’s will be sent a text format of license file in which the object range is defined. reagrds MK
Hi Simon perhaps this thread can help you: http://www.mbsonline.org/forum/topic.asp?TOPIC_ID=5982 bye André
JUst create a simple form based on the license permission table. Make sure of course that you are using the clients license when running the form.
quote:
Hm, if we are speaking about N3, there is no permission range table.
We have a lot of Customers. Not all are using the same object ranges (inherited etc). I wanted a “global” solution if possible! My first thought was to create an almost empty db which you could run against any licence - but there doesn’t seem to be a parameter on fin.exe which allows you to specify the licence file
We aren’t talking FIN.EXE here - this is the forum for the text based version, the old one.
quote:
Correct [:I]… we need a moderator to move it to the correct forum.
