V4 SP3 Navision Crashes when copy field
Hello,
Have a customer running V4 SP3 whenever he copies the values in a field using mouse right click copy it crashes Navision. He is running XP and other users with the same problem are running Windows 7.
I have restored a backup and I don’t get the same problem. I have even loaded the Build I am running onto clients PC to see if this resolves but doesn’t. Gave user super permissions but this had no effect. So I am completely stuck without support from Microsoft who of course no longer support this.
Any ideas or suggestions would be welcome ?.
Regards
Andrew
Is it a specific field or any field?
Have you tried deleing the zup file?
Perhaps some faulty action is assigned to right click (Shft-F10)
http://www.mibuso.com/forum/viewtopic.php?f=5&t=29722
Does copy & Paste work without issue using Ctrl-V & Ctrl-C?
