I want to compare a date field with the current date of the system
My field is then call eg DateField and I want to display the commands in this record day, knowing that my field is type UtcDateTime.
datefield> = dateSystemBeginDay
datefield <= dateSystemEndDay
then there exists a method that defines and dateSystemBeginDay dateSystemEndDay
thank you
Welcome to DUG!!!
Can you just more elaborate on your question ???
This is AX! Moved from Dynamics NAV / NAVISION Developer forum to Dynamics AX Developer forum.
Posted on your other thread…but here is code again:
static void Job72(Args _args)
date systemDate;
utcDateTime utcStart, utcEnd;
systemDate = DateTimeUtil::date(datetimeutil::getSystemDateTime());
info(strfmt(“System Date: %1”, systemDate));
utcStart = DateTimeUtil::newDateTime(systemDate, 0);
info(strfmt(“UTC Start: %1”, utcStart));
utcEnd = DateTimeUtil::addDays(utcStart, 1);
info(strfmt(“UTC End: %1”, utcEnd));
