UTCDateTime table field value not persisting
Hello,
I am assigning a correct date value to a UTCDateTime type field on a table. The value is assigned right before a record is inserted. Strangely, the value is not saved even though when I step through the debugger, the value is assigned and saved when I step through the code with the debugger. Meaning, even after the insert() method is called, the new UTCDateTime value appears as the value for the date field in the debugger’s watcher. However, when I table browse for the record, the UTCDateTime field value is null.
Any thoughts on this?
Thank you!
Hello,
Can you share the code that you are using to assign a value to the utcDateTime type field of the table while inserting a record in the table? Are the other fields values in the record being inserted getting saved properly?
