Using XBRL Reporting from Axapta
Greetings All, I’m trying to use the XBRL Reporting functionality in Axapta - GL Module - Reports - Transaction - Periodic - XBRL Reporting. I followed the minimal documentation in Help - ie. 1. first Setup Taxonomy through Posting Menu (I used the us-gaap-ci-2000-07-31.xsd sample taxonomy file.) and from the tree structure I mapped the Current Assets entity. 2. Used XBRL reporting - it outputs a .xml file. My Problems: 1.This .xml file contains only and info. I believe it should provide me with a tree structure showing all the different accounts which are present in my Chart of Accounts - GL. Why this behaviour? 2. i was under the impression that XBRL Reporting would provide me a fancy output report in web format or something but it just throws out an .xml file. Do we need to program using XSLT? Or is something available within Axapta which I’m not aware? Any help would be appreciated…Thanks. Dilip
