Writing a dataport into the contact table, I see that there’s a function CreateInteraction, which is (hopefully) exactly what I want to do. How do I discover what it does/how to call it ? Is there documentation somewhere, or some magical way of expanding it in the dataport code window, or do I have to have full access to the table code to read the source ? If it isn’t something I can generally discover for myself, can someone tell me how this function works ?
You need to be able to go to Table source code. There is no magic way. I don’t know if it okay to put the table source code here.
Hi Chris You could also use the Developers Workbench Tool, but I guess that you don’t have full developers licence just dataport designer, in this case you can use the functions in Navision Objects but not view them.
Originally posted by Chris Sharman - 2005 Feb 07 : 15:19:50
You don’t. Anyway Contact.CreateInteraction is the function which is launched by the “Create Interaction” command button on the Contact Card. It builds a temporary table then runs the Create Interction Wizard form. Hardly something you may want to do in a dataport. [:)] Anna
