Using Printer Built in fonts - doesn't seem to work
I’m trying to print a report to OKI 395 dot matrix printer. If I select DeviceFontName Courier 6 cpi in the Report Properties form and try to print the report, nothing happenes. Printer still prints everything in graphics mode. Is there any trick?
Yep - There is a trick - Here goes. Go into the sections of the report: On ALL “Boxes” select Properties, and make sure that all FONT properties are set to the default value (Delete current value). The DeviceFontName only works on “Boxes” with Default Font Values! Kind Regards – Henrik Helgesen, Navision Solution Developer
If you wanna change graphic mode font, Henric is right. If you wanna print on text mode, no way. NF using Windows printing, supported only graphic mode.
