I m working on ADCS.And when i m trying to conect to VT100,it is asking password,even i entered right one.i used sa as user id,which is my only DB Log in user…
could u say wt’s problem behind…?[:’(]
Regards
Shravan
NAV Developer
Regards
Shravan
NAV Developer
Hi Shravan,
Is this the ADCS logon minform?
Did you check the user is setup on the user table?
Hi DaveT,
Yes.I am using ADCS logon Form and User Setup is done Well.
My Problem Resolved.Login failed due to I didn’t setup user as employee properly.
Regards
Shravan
Hi DaveT,
yes,it.is.user setup is done well in user table.Actually login failed due to the user setup is not done well in the Employee table.Now it’s resovled.
Thanks & Regards,
Shravan
