I want to trigger a CU in another company from C/Al code. The approach which I am using is as follow:
I created a CU which Insert a rec for me ----> This is the CU that I want to trigger (It takes a Rec as Parameter)
I created another CU which will call the first code unit as follow:
Global variables:
OK ----> Type Boolean
Session Event ------->Rec (Table Active Session)
Resulttable ------- >Rec that I want to pass
// CODE****
Resulttable.FINDLASt; // Get the last rec in my result table
OK := STARTSESSION(SessionEvent.“Session ID”, CODEUNIT::“MZA Insert In Table”, ‘Test Company2’,Resulttable);
IF OK THEN
STOPSESSION(SessionEvent.“Session ID”, ‘Rec was Inserted’)
ELSE
ERROR(‘Session was stoped’);
// *****CODE
The issue is that I tried to fire the CU which include the start session function and it always works one time only!!
I have to restart Navision server 1 time before I can fire this CU once again. any idea why the CU is working only 1 times??
PS: The above code works only if I fire it while tracing it with the debugger! if I fire it without tracing it wonot work?? really strange?
