Hi all!
what is the an easy way to link a drawing No into several Part numbers in Navision?
My customer has a Engineering dep that manages Item numbers, BOM numbers and drawing nos and they want to be able to see:
In which parts numbers an existing drawing number appears
for a specific part number, where are the different drawing nos.
They are using Manufacturing in Navision.
So the way that i did that was t:
Create a drawing no as an item part in Navision
Create a an assembly list where the drawing number will be inserted so that we can used the 'where used "option. But in that cas how can i have multiple boms for the same item. ( I’m not talking here about the PBOM but the assembly list) .They will also used a PBOM but really for all inventory components.
So pleas guys if you have some suggestions I am open.
Thanks in advance
