I have added RR assembly for .NET (RR.dll) in References in Dynamics AX 2012 .i used this .dll file in a class.
Then I moved all the code to a method with RunOn property set to server as I dont want to run it on client side. Now, when I execute the same X++ code it gives me the following errors.
Assembly containing type “RR.eft.constant.eftservice” is not referenced.
Object ‘CLRObject’ could not be created
Initially, during testing on client method, I placed .dll file in my …/Client/Bin folder and added reference from my AOT.
Next I placed it in …/Server/…/Bin folder and added reference from my server’s AOT and then tested the method with RunOn property set to server but it is not working and gave me the above mentioned errors.
Please help me as I have been working around this issue for a week and could not get any solution.
One potential problem is that AX client is 32-bit process and AOS is 64-bit process. Also, even if your assembly is all right, it may not be loaded if some of its dependencies can’t be loaded by any reason.
Thanks For the Reply,what is the solution for that.
Thanks in Advance,
sudha
It depends on what’s the problem.
If you have a .DLL built for another processor architecture, built it again for the right one. If you can’t, you’ll need another process (e.g. another service communicating with AOS).
If it’s caused by some referenced assembly, you have to find which one it is and identify why it’s not loaded (missing on AOS machine, 32-bit or so).
Thanks for the reply.i called this dll in a job.it is working there but in my class it is trowing error.can u please help me in this issue.
Thanks in Advance,
sudha
I don’t know anything about the library nor your system; you’re the only one who can analyze what’s wrong.
First check processor architecture of the .dll (you can use CofFlags.exe, for example). Then check what components are required by the .dll. Often you can see something obvious what’s not in the machine on question. If you don’t see anything suspicious, try Assembly Binding Log Viewer.
How to Call a .net C# sharp code in Ax2012
1.open visual studio 2010 create a new C# project in that open class library write the following code
using System.Text;
namespace AXCS
public class TestingMyDLL1
public string Greet(string name)
return "Hello " + name;
2.Bulid the solution
3.go visualstudio projects—> copy dll files
4.program files(X84)–>microsoft dynamics—>client—>bin—> paste Dll files
5.open AOT–>go referencess —>.add reference–> add that dll files
6.Go to jobs–> Add new job write that following code
static void testingNETCode(Args _args)
MyDLL1.TestingMyDLL1 testingDll;
InteropPermission permission;
str s;
try
permission = new InteropPermission(InteropKind::DllInterop);
permission.assert();
//System.Windows.Forms.MessageBox::Show(“Hello pavani”,“AX”,System.Windows.Forms.MessageBoxButtons::OKCancel);
testingDll = new MyDLL1.TestingMyDLL1();
s = testingDll.Greet(“Pavani”);
info(s);
catch
error(‘Error executing DLL code’);
- Execute job
Alex, what fix are you looking for? Does it belong here? Shouldn’t you create a new thread for your question?
Hi Drab
We are also facing the same issue as we are able to call the dll from Job and not from the class.We have built in both 32 and 64 Bit CPU.Please share your thought on this…
Hari
I already did that above. There are more reasons why the assembly can’t be loaded, such as that you miss certain referenced assemblies on AOS. The Assembly Binding Log Viewer will help you if you don’t see anything wrong.
Hi Hari,
Please try to use the dll Microsoft.Dynamics.AX.ManagedInterop for getting the reference.
Parthiban
Hi Pathiban,
What do you exactly mean by saying use “Microsoft.Dynamics.AX.ManagedInterop” as reference? Where? in AX code? or the DLL that was created?
Please let us know.
Thanks.
