Dear All,
I need to grant access to end users in Navision 4.0.
Can we capture each and every users works by accessing the code coverage using single machine (i.e Server).So on that basis I can provide access
Is it possible???
Regards
Amol
Dear All,
Is it possible???
Regards
Amol
That’s a bit of a loaded question.
Technically YES you can do this, and there is a tool that will capture the required objects and generate the permissions. BUT…
In the real world, you must think of this just as a starting point. The key issue is that say for example you post and Invoice. There are so many differnt options in posting, that it is extremely unlikely that you will cover them all, so soem objects will be missed. Of course its a great start, but don’t trust this to be the final version, you will still need to do some manual tuning to make it work how you need it to.
Oh anothe issue, is that sometimes the opposite can happen, where during the code coverage you accidently run somethign you didn’t mean to, and suddenly you find a whole bunch of users with permissions you never meant them to have.
Hi David,
Thanks for the reply.
Can you just suggest the tool that will capture the required objects and generate permission.and of course it reuired some manual fine tuning.
Please provide the tool name
Regards
Amol
I guess David is referring to this one: http://www.mibuso.com/dlinfo.asp?FileID=277
Once I worked for a company which was using this to setup the user rights; that’s how they proceeded (briefly):
Technically, this was not that difficult, but most of the effort was spent on planning on what to record and how to structure all the rights & roles. And as David mentioned, here also a lot of “fine tuning” was necessary afterwards. So in total it took several weeks to setup all the roles.
The smart thing here - IMHO - was, that the IT guys delegated the responsibility for hardening to the department managers who are actually in charge …
Kind regards,
Jörg
Now that I like, very neat way to get them to take responsibility.
How do you report on this…does the tool have a report?
