We have some problems configure MS Proxy Server to support User Portal. We have no problems within the LAN but when outside… Thanks, Henrik
User Portals aren’t designed to let people in outside your LAN. The usual suggestion is to setup a VPN for ‘outside’ access. Django
Thanks Django… but how can that be possible? Henrik
Using the VPN method you connect to the Internet, start your VPN software which gives you the ability to log on to your network somewhere else in the world. Once you are logged in to the network you should be able to go to your user portal. That should do it. [:)] Django
