User Portal Installation / Windows Authentication
I have installed User portal and when I am trying to start the User Portal, it is giving a error in the browser has ’ User Portal Application Server must be opened with Windows Authentication’ I am starting the client with ‘runasupas’ program property and starting the user portal How to solve this problem.
Hi I think the problem is that you did not open the database with windows authentication? Regards //Kalman
Add NTAuthentication=Yes to the shortcut. Also make sure the user is defined in Tools–>Security–>windows login
…and make sure the user has sufficient rights and that they have assigned activity centres, etc… [:)]
