User permission set up does not allow marking of open transaction editing in general journal
Hi Experts:
I used the security profiler to know the security needed to set up so that a user can use the general journal for vendor transaction. I set up below keys as FULL CONTROL, however, when the user try to click FUNCTIONS>SETTLEMENT, the and then mark the transaction, the transaction does not go to the journal. Is there any set up that I missed?
Your replies would be greatly appreciated.
Heylin
Same issue has been raised for the AP payment journal. upon clicking function>settlement>mark the open transaction, the marked transaction does not go to the journal line. :frowning:
Does it shows any error? Does the same transaction happens with the user having the admin rights/ all rights?
Under the ADMIN group, it does not happen. And no error logs during this transaction.
To resolve the error, I set the ALL the modules under SECURITY to full control and then one by one rest the node to no access for the modules that i don’t need. I also set no Access for the main menu items that i do not need. the marking of open transaction now works fine.
Hi Heylin,
I think you have already solved this issue. I also face same issue. After I setup everything for each user group, user hits this issue. So, I have difficulties to redo everything.
What I did is Go to Main Menu > Account Receivable > Customers > Customers > Customer (without ‘s’) > Function folder > give full access to ‘Open transaction editing’ and ‘Close transaction editing’ which are not cascade even we give full access and click cascade to root ‘Customer’.
I did it as last step. Then it works properly.
Myo Sandar
