user name in a windows login environment
how do i determine the user name in a windows login environment? there is a windows login table in navision, but the name field in that table is empty… but when i click on the help file, it tells me that this field should display the user name.
Jordon, Have you set up the AD in the Window OS? Then you can add the name to the Window login through the security function. It should be specified in the installation menu.
i have set up AD in the window OS. as a matter of fact, i have finished setting up all the users and user permissions. the only pronblem is how do i extract the user name from the windows AD from navision?
