User Logged in Details as Report
In Administration → Users → Online Time, When we select a user and click the “Online Time” it generates a report in which we can get the total hours logged in for a particular user.
In the same way i need to generate report,in which i can get 3 input criteria (user id, from date, to date)according to that the report should generated. And the fields i should get are
  1. user id , 2. total hours logged by the user , 3. total no of times the user logged in
Please Help.
Rajee
HI Rajarajeshwari,
Try this…you will get an idea…
Exportfile for AOT version 1.0 or later
Formatversion: 1
***Element: RG
; Microsoft Dynamics AX Report: Users unloaded
VERSION 1
REPORT #Users
PROPERTIES
Name #Users
ENDPROPERTIES
METHODS
Version: 3
SOURCE #classDeclaration
#public class ReportRun extends ObjectRun
UserId userId,user;
TransDate fromDate;
TransDate toDate;
UTCDateTime fDateTime,tDateTime;
DialogField dialogUser;
DialogField dialogFromDate;
DialogField dialogTodate;
ENDSOURCE
SOURCE #fetch
#public boolean fetch()
Query q;
QueryBuildDataSource qbds;
QueryBuildRange qbrUser,qbrDate;
QueryRun qr;
TimeZone tz;
q = new Query(this);
qbds = q.dataSourceTable(tablenum(SysUserLog));
qbrUser = qbds.addRange(fieldnum(SysuserLog,UserId));
qbrUser.value(userId);
qbrDate = qbds.addRange(fieldnum(SysUserLog,LogoutDateTime));
fDateTime = Global::datetobeginUtcDateTime(fromDate,tz);
tDateTime = Global::datetobeginUtcDateTime(toDate,tz);
qbrDate.value(SysQuery::range(fDateTime,tDateTime));
qr = new QueryRun(q);
while( qr.next() )
SysUserLog_1 = qr.get(tablenum(SysUserLog));
user = SysUserLog_1.UserId;
element.execute(1);
return true;
ENDSOURCE
SOURCE #getFromDialog
#public boolean getFromDialog()
userId = dialogUser.value();
fromDate = dialogFromDate.value();
toDate = dialogToDate.value();
return true;
ENDSOURCE
SOURCE #dialog
#public Object dialog(Object _dialog)
DialogRunbase dialog = _dialog;
dialogUser = dialog.addFieldValue(typeid(UserId),userid,“User”);
dialogFromDate = dialog.addFieldValue(typeId(TransDate),fromDate,“From Date”);
dialogToDate = dialog.addFieldValue(typeId(TransDate),toDate,“To Date”);
return dialog;
ENDSOURCE
ENDMETHODS
QUERY #Query
PROPERTIES
Name #Query
Version #1
NextUniqueId #1001
ENDPROPERTIES
METHODS
Version: 3
#public class QueryRun extends ObjectRun
ENDSOURCE
ENDMETHODS
BLOCKS
BLOCK #SysUserLog
PROPERTIES
Name #SysUserLog_1
Table #SysUserLog
UniqueId #1000
ENDPROPERTIES
FIELDLIST
PROPERTIES
ENDPROPERTIES
ENDFIELDLIST
SORTING
ENDSORTING
LINES
ENDLINES
BLOCKS
ENDBLOCKS
GROUPBY
ENDGROUPBY
ORDERBY
ENDORDERBY
ENDBLOCK
ENDBLOCKS
DEPENDENTS
ENDDEPENDENTS
COMPOSITEQUERIES
ENDCOMPOSITEQUERIES
ENDQUERY
DESIGNS
DESIGN
PROPERTIES
Name #ReportDesign1
ENDPROPERTIES
AUTOBODIES
PROPERTIES
ENDPROPERTIES
CONTROLBLOCK
PROPERTIES
Name #ProgrammableSection
ENDPROPERTIES
METHODS
Version: 3
SOURCE #getUserId
#display UserId getUserId()
return user;
ENDSOURCE
ENDMETHODS
STRFIELD
PROPERTIES
Name #getUserId
DataMethod #getUserId
ENDPROPERTIES
ENDSTRFIELD
ENDCONTROLBLOCK
ENDAUTOBODIES
ENDDESIGN
ENDDESIGNS
ENDREPORT
***Element: END
Naresh Kolli
Thanks Naresh,
But how can i calculate the "Total Logged in time & Total no of times the user had logged in "
Any ideas, Please share
-Rajee
HI Rajarajeshwari,
There is a methods “onlineTime” and “onlineTimeHours” in the table - SysUserLog level…you can use those methods in the report to display the total logged in time…And for every Login it creates a record so by records you can know the total times logged in…
Naresh Kolli
