c
This user can modify the Item Card for Model/Finish/Cover/Size extension fields but there seems to be a lag between when she types this info on the card and when she sees it . Then, there is second lag with transfer to Sales Order when Item is added to the line. Your thoughts?
Is this a SaaS implementation or OnPrem? I’ve also seen some delay in the SaaS version when updating fields so this may be a known issue.
What Version?
Is there any code associated with the extension fields or was it just adding the fields to the table?
