I’m using NF 2.01B W1 and I have to print to a Epson FX 2180 Matrix printer. With this printer we use 2 different paper formats (continuous paper). For one format I found an option in Navision but for the format 206 x 150 cm I have some problems. I checked the old postings in this database but could not find any solution. How can I setup this paper size so that Navision is able to print more than 1 page? Thanks
There are two things I’m going to mention from your post. #1. I’m not sure by your post if you understand this or not, so I’m going to state it anyways. Navision doesn’t handle the property for page size as defineable during runtime. To be able to print two different sized paper, you require two different reports in Navision (one for each size). #2. If what you’re looking at is how the paper sizes are set on the “PaperSize” property of the report that aren’t listed, then all you need to do is leave the “PaperSize” property set as . Then, you set the margins in your Section view to whatever you think you need, and let the printer control the papersize during print. You can still set margins and everything else. I don’t know if the “Orientation” property will work with “Landscape” using this method…
