Use variable in multiple classes
Thanks in advance!
Very new to AX, so be specific in response if you can help and don’t worry about offending me, because I already feel stupid when it comes to this so far.
I’m manually setting the report design at runtime based on a parameter using the following in ReportController\PreRunModifyContract.
protected
void preRunModifyContract()
myReportContract contract = this.parmReportContract().parmRdpContract()
as MyReportContract;
this.parmReportContract().parmReportName(this.getReportName(contract));
super();
The ReportName variable is populated in ReportController\GetReportName method and returned to this method.
Okay, my question is how can I access this variable (ReportName) in another Class?
I want to use it in the ReportDataProvider class\insertToTempTable method so if the design is ‘report design 1’ then run a specific method to populate a group of temp table variables…else if it is ‘report design 2’, run a different method that will populate the same fields with different values.
Or…is there a way I can retrieve the report design name from the report properties (since it should already be set at this point)?
The simplified version of my code will look something like this:
// I need to get ReportName value before the following code executes…either from other class or from report properties?
If(ReportName == ‘Report Design 1’
myVariable = myTable.method1().value;
Else
myVariable = myTable.method2().value;
Thanks for looking. Hope someone can help.
Use the following code.
if( element.design().name() == ‘Report 1’)
// your code
else
// your code
Thanks.
I just tried it, but I get ‘Variable element has not been declared’.
