Use of XBRL taxonomies
hi
i m facing a problem with XBRL taxonomies. Can u help me that how to import taxonomies into navision. I would be greatful if u help me in this.
What version are you using? I believe on the UK version you need v4SP2 or higher
Cheers,
John.
thanks for ur reply…
m using NAV 4.0 with SP2… but i m not aware how to import taxonomies in to navision.so can u help me out how to import taxonomies…i wuld be grate ful…
Try following the links from the XBRL website below to get your scheme and linkbase files : -
http://www.xbrl.org/TechSupport/
Also, I suggest you use the online help, which is very good and explains the steps you need to take.
Cheers.
John.
